Author Topic: carbon canister - removal  (Read 1010 times)
Offline GavGti
« on: 17 May 2008, 22:19 »
heard this can be removed
any tips/pics/advice/help
if it isn't a major job ie: disconnect few pipes, bolts etc then prob fine with it, just never looked closely at golf before, i'm a vauxall man previously
if it's removed i should have room for cold air feed if i'm right
Offline Guy
Re: carbon canister - removal
« Reply #1 on: 17 May 2008, 23:36 »
ask Mikester... I think he managed to remove his in one go the other week!  :laugh:
Offline Mikester
  • Civic Type R
« Reply #2 on: 17 May 2008, 23:39 »
Well yes, mine is still firmly fixed to the car, but it has a gaping hole in it, so its not working, and yeah, it can be removed, as the car runs fine without it.
Best to remove the bumper to get to it
then just connect the in and out pipes up. And bobs your uncle and fannys you aunt. I still have mine connected, but with a hole in it, and it runs fine. Its a bit sluggish but i think it needs new plugs etc. Not c/canister related.
Offline Pete Taylor
« Reply #3 on: 18 May 2008, 07:12 »
You should block the throttle body side
Offline bored_Welsh_lad
« Reply #4 on: 18 May 2008, 10:49 »
hi, disconnect plug from unit on arch and then remove tubes from canister, discard canister and plug the black hose to stop fuel vapour entering bay- hey presto!
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
