The garage
Bad Idle
Topic: Bad Idle (Read 1684 times)
Danr
Bad Idle
26 April 2004, 22:04 »
Ok my mk1 1800 8v (well 1.9 8v but cant c there being any difference) has decided to go crazy, when the car starts it idles at 1200rpm then after drivuing for a while either fast or normal it drops to about 500 or just drops to 0 when u stop, car will start fine the run do same after a while but sometimes it will idle at 200 and not die, the car does have fast road cams but they have been fine and fault only stared the other night
any ideas on what to do
mk1
2ltr16v turbo (now with programmable EFI)
Re:Bad Idle
26 April 2004, 22:23 »
Check there are no vacuum leaks, there is a idle adjustment screw on the bulkhead side of the throttle body. When the engine is hot adjust it (out is faster) to give a idle speed of around 950 rpm.
Steve.
http://www.geocities.com/mk1turbo16v/golf_turbo.html
Danr
Re:Bad Idle
26 April 2004, 22:30 »
BUt would it just go for no reason, as it had been running really well lately
mk1
Re:Bad Idle
26 April 2004, 22:34 »
Check all the pipes and hoses especially the pleated rubber pipe on the metering unit and throttle body. Could have a small air leak witch will allow unmetered air into the engine causing a weak mixture.
Steve.
The garage
Bad Idle
