Author Topic: idle  (Read 686 times)
Offline paul73
idle
« on: 17 May 2008, 18:22 »
Hi,
My car, since cleaning the throttle body, has started to idle high (around 1200rpm) every so oftern. Any ideas why?
What can i do_?
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: idle
« Reply #1 on: 19 May 2008, 12:44 »
Mine did this,  I dont know what engine you have but i did it on a 1.4L AEX engine.
What i did was run the engine,  then pull off the brake servo pipe coming from the throttle body/manifold the revs went high and it tryes to stall etc..  then pop it back on and it was fine ever since.  Not sure of the cause but it worked for me..  Or disconnect the battery for 10 mins and reconnect. It will then relearn all the engien settings etc..
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
