Author Topic: MK4 110 TDI Imobiliser  (Read 1313 times)
Offline Lee_dub
« on: 17 May 2008, 17:55 »
Father in law just got one and it has two imobiliser keys, however he doesn't have a clue where you can put them ive had a look and can't find anything either, any ideas?
Oh and its using alot of water\coolant anybody know?
Cheers  :smiley:
Black mk1 2.0 16V - woop
Offline richw911
Re: MK4 110 TDI Imobiliser
« Reply #1 on: 17 May 2008, 19:05 »
Must be an aftermarket system because the standard vw imobiliser is built into the key  :undecided:
Offline Lee_dub
« Reply #2 on: 17 May 2008, 20:50 »
Cheers mate
Anybody know about the coolant?  :smiley:
Offline Rhyso
« Reply #3 on: 17 May 2008, 20:51 »
Cheers mate
water leak from somewhere  :undecided:
Offline Lee_dub
« Reply #4 on: 17 May 2008, 20:53 »
Checked that, no leaks and no mayo in oil cap either......
Offline Rhyso
« Reply #5 on: 17 May 2008, 20:56 »
i assume its performance is fine  :huh:
any smoke or similar out the back? need to get it scanned to see if it throws up any codes
Offline Lee_dub
« Reply #6 on: 17 May 2008, 21:00 »
Na performance is fine, no smoke either its confusing I know, I think your right mate its one for the Vag com..
Cheers lads
Offline T_J_G
« Reply #7 on: 17 May 2008, 22:08 »
I have the same car and my rad was leaking from both sides. noticable when parked but you can't see anything due to the bumper and all th plastic around it.
Offline Lee_dub
« Reply #8 on: 18 May 2008, 14:18 »
Another weird thing discovered today, When it gets low on water the indicated temperature drops!! I was thinking there might be a problem with the thermostat, like its stuck or somthing?
Offline Rhyso
« Reply #9 on: 18 May 2008, 15:04 »
faulty temp sender
faulty water pump
 :undecided:
