Author Topic: is it a straight fit  (Read 922 times)
Offline 1688bran
« on: 17 May 2008, 14:28 »
  will r32 front brake fit straight onto the mk4 turbo ..
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: is it a straight fit
« Reply #1 on: 17 May 2008, 16:00 »
Yes, although you'll need the calipers (you'll also have to bleed the brakes), carriers, discs & pads.  It's an expensive mod & is a bit overkill, IMO, as the turbo is a lot lighter than the R32 (unless you're planning to run 300 + bhp).  Plus, replacement discs are bespoke, IIRC, so therefore will cost a fortune to replace.  You'll also need 18" wheels if you haven't got some already.  (Maybe SOME 17's may fit, but I can't remember).
Best option for your £Â£Ã‚£ would be the 312 set-up (easier upgrade) & spend £120 on some decent pads, such as the amazing Ferodo DS2500's.  :afro:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline richw911
« Reply #2 on: 17 May 2008, 18:35 »
Yeah as ivor says ^^^^^ :afro:
This is a big help... http://uk-mkivs.net/forums/post/1014271.aspx
