Author Topic: MK2 16V Cold Start PROBLEMS  (Read 4066 times)
Offline e700
« on: 17 May 2008, 14:06 »
My 1988 16v is a b!tch to start when it is cold, i have a good battery and after about 2 minutes  of constant turning over it fires up. It starts great when it is warm and performs fantastically
please help
1988 Monza Blue 16v
Offline rowlers
  • I'm back - MK7 GTI
Re: MK2 16V Cold Start PROBLEMS
« Reply #1 on: 17 May 2008, 21:57 »
leaky injectors?
drip drip overnight, the loads of cranking to clear the fuel the she fires!
get new mercedes injectors off ebay for 1/2 the price of vag ones :wink:
Offline perryqhill
« Reply #2 on: 17 May 2008, 22:13 »
Mines the same - either cold start valve, it's sender or injectors.
Can't be arsed to sort it now the weathers warm though - caused many a flat battery though  :sad:
Offline Conker
« Reply #3 on: 17 May 2008, 23:52 »
My cold start valve has been disconnected throughout winter and its always started fine (maybe a couple of seconds slower to fire up than it should, but thats all).  What I mean is, don't assume the CSV is vital for starting the engine.
If it was me, I would look at the electrical side of things first: clean all contacts, new plugs, rotor arm, and maybe the coil (??). Then injectors.
As Rowlers said, I bought the merc one's off ebay and they were fab, plus not much more than having the old one's cleaned.
Good luck.
