Author Topic: WOT SPRING IN THE FORGE 007  (Read 3289 times)
Offline samy_1800_turbo
« on: 17 May 2008, 11:39 »
i found that my forge valve was leaking wen i checked the o-ring and saw i had a green spring in there which forge say is to be the weakest spring, i had a revo remap so should i have the next spring up or is the green still ok, wot av you boys got in yours.
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
Re: WOT SPRING IN THE FORGE 007
« Reply #1 on: 17 May 2008, 18:00 »
i have a green 1.i phoned awesome gti because i had mine remapped to c if the green 1 was ok so they got in touch with forge and it is the right 1.
Offline mk4Martin
  • Midlands VW
« Reply #2 on: 17 May 2008, 19:27 »
i was running the green spring but found i was loosing boost under heavy load . told forge and they sent me a yellow spring which i think holds alot better .
forge will advise you also to but the dumpvalve in reverse position as this can also work better
Offline MaXXeH
  • Golf MK5 GTI
« Reply #3 on: 17 May 2008, 19:36 »
i also have a yellow spring, makes it loads better
Offline (shakey)
« Reply #4 on: 17 May 2008, 19:47 »
how much is the yellow spring or will they send it 4 free,what do u mean reverse position.
Offline MaXXeH
  • Golf MK5 GTI
« Reply #5 on: 17 May 2008, 19:51 »
i had to pay £11
Offline mk4Martin
  • Midlands VW
« Reply #6 on: 17 May 2008, 20:23 »
they sent it free for me . basically to put it in reverse the big pipe that is down facing is turn clock wise and inserted to the pipe on the left and visa versa . foget what i just said , you would be better off finding a guide but its very easy to do  :huh:
Offline limmy
« Reply #7 on: 17 May 2008, 20:31 »
yellow mate. You will need this as the car will at slightly higher boost (0ver 15Psi)
« Last Edit: 17 May 2008, 20:34 by limmy »
« Reply #8 on: 19 May 2008, 01:07 »
i got mine in reverse i found its better dont no y seemed to hold boost slightly better, i mite have to get the yellow spring where do i get the springs from
Offline mk4Martin
  • Midlands VW
« Reply #9 on: 19 May 2008, 09:28 »
forge wesite . about 15 quid . forge did explain to me why is works better in reverse but it just went straight over my head
