Author Topic: Lumpy running, vag come analysis help?  (Read 967 times)
Offline Mike20vT
« on: 16 May 2008, 17:58 »
the cars been missing like a mofo recently.... plugged the vag com in and got the following returned:
16486
 P0102
 Mass or Volume Air Flow Circ Low Input
16514
 P0130
 O2 Sensor Circ.,Bank1-Sensor1 Malfunction
16955
 P0571
 Cruise/Brake Switch (A) Circ Malfunction
17545
 P1137
 Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
17704
 P1296
 Cooling system malfunction
17705
 P1297
 Connection turbocharger - throttle valve pressure hose
so by the looks of that i'm having some trouble with cyclinder 1, a split boost hose and the MAF???
anything else to look for/replace??
thanks in advance
Mike
Offline Rhyso
Re: Lumpy running, vag come analysis help?
« Reply #1 on: 16 May 2008, 18:05 »
ouch  - thats a lot of codes lol
as you've said replace the coil pack, MAF and check for split hoses
also replace the brake switch behind the brake pedal - £8 from stealers and 10 minutes to replace
Offline Mike20vT
« Reply #2 on: 16 May 2008, 18:17 »
so its defo the coil pack on cylinder 1??
any idea what the "sensor circ bank 1" is?
Offline Rhyso
« Reply #3 on: 16 May 2008, 18:23 »
yeah reaplce that and it looks like you've also got a faulty O2 sensor / Lambda sensor
http://wiki.ross-tech.com/index.php/Special:Search?search=P0130&go=Go
