Author Topic: hiss from turbo?  (Read 2566 times)
Offline gib6107
hiss from turbo?
« on: 16 May 2008, 09:47 »
I've just had fans replaced as they were faulty (coming on intermittently with AC on). Now I'm getting a noisy hiss which I think is from the turbo. It used to whistle but now hisses. Does this have anything to do with the new fans/cooling system or is it a separate problem? Maybe something the mechanic has done wrong as it wasn't doing it before!
Offline Ridg
  • TDI - Soot Happens!
Re: hiss from turbo?
« Reply #1 on: 16 May 2008, 10:45 »
if he's had the radiator off to change the fans, theres a chance some of the pipe work would have been taken off too, could be that one of the peices hasn't been put back on properly and you've got a boost leak.
have you noticed any power loss / bluey white smoke under acceleration?
Offline gib6107
« Reply #2 on: 16 May 2008, 10:54 »
No power loss noticeable, nor seen any smoke. Still drives well.
