Author Topic: Suspension quicky??  (Read 1098 times)
Offline shaft69
Suspension quicky??
« on: 16 May 2008, 07:20 »
Is corrado suspension same is mk3? My mate has set of coilovers i can have cheap of his 16v corrado for my mk3. Thanks.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline boneybradley
  • Back in a Mk3...
Re: Suspension quicky??
« Reply #1 on: 16 May 2008, 08:37 »
No as the corrado uses a modified mk2 shell.... I do believe the rears fit but not the front....
« Reply #2 on: 16 May 2008, 08:49 »
I asked the same question 2 weeks ago and was told they were the same.
Offline suzyGTI
« Reply #3 on: 17 May 2008, 12:46 »
this is probably too late but no they arnt the same
check out this link and it shows differant part numbers.
ive had hell with suspension lately  :sad:
http://www.spax-suspension.co.uk/vw_c33657_33664_33667_7871.htm
Free image hosting by http://www.holdthatpic.com/
Offline filthy
« Reply #4 on: 17 May 2008, 17:33 »
Corrados use MK2 Golf front suspension and B3 Passat rear suspension....
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #5 on: 17 May 2008, 23:16 »
But Mk2 suspenssion fit its a MK3 ?!?!
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
