Author Topic: The project golf  (Read 2316 times)
Offline cняis
The project golf
« on: 13 May 2008, 22:07 »
Right then...!
A few of you might recall my problems with the project golf. its an early 89 digi gti, so has the earlier wiring (hazard switch on dash) and square expansion tank.
In a nutshell:
- Dry stored for 2 years, never fired up within this time. When it was stored it was a runner.
- Got the car in December, new battery fitted and it fired up for the first time in January, ran for 20 mins no problems.  :smiley:
- 3 weeks later tried starting it again, and it fires but stalls when the key is returned to position 2.  :angry:
- Replaced the ignition switch and will no longer fire at all, just turns over and smells of fuel, sometimes backfires whilst turning over.  :angry: :angry:
- April comes along. Cleaned up all earth points and double checked all wiring for breakage etc, still wont fire at all.
This evening i've been a busy boy:
- Tried starting ot on the off chance and again it will fire as long as the key is held in position 3 (starter winding over). Release it to pos 2 and it stalls instantly.
- Swapped ignition module, then the whole ECU, from my daily to the project
- Swapped the MAF from the daily to the project
- Swapped the HT leads from the daily to the project
And.... still nothing!  :angry: :angry: :angry:
Now im seriously fed up. I have the suspicion it may be timing related, perhaps the belt is worn and slipped around a tooth or so.
Luckily the GF works with the wife of a VW/Audi tuning specialist (does superchips, engine tuning and MOTs), so i shall now be (begrudgingly!) getting the pro's in. ive had enough but i wont be eaten.
Until he finds the time to look at the car, anything else u should be checking? something else i should note is that about half the time the fuel pump wont prime. but its getting fuel as i can smell a little bit of petrol and it occasionally backfires.
Offline Khare
  • The bear that khares
Re: The project golf
« Reply #1 on: 13 May 2008, 22:11 »
get a new ignition coil, or even a recon. or try the one from the daily.
timing wouldnt explain why it stalls when returned to position 2. So its definitly electric. as i said, try the ignition coil.
Offline cняis
« Reply #2 on: 13 May 2008, 22:24 »
this is the thing that the king HT lead goes into by the expansion tank yes?
please excuse my ignorance as im very much learning as i go along!
Offline Khare
« Reply #3 on: 13 May 2008, 22:27 »
spot on there. Try replacing it with your daily's coil to cut down the list.
Offline cняis
« Reply #4 on: 13 May 2008, 22:38 »
thanks
how much ball ache is it to remove? i know the wiring and plumbing for the heater is a bit tight around there
Offline dubvrs
« Reply #5 on: 14 May 2008, 11:08 »
What happens if you start it and put your foot on the throttle a little bit.
Mine was off the road 7 years before i got it and it started and stalled. If i put my foot on the throttle a bit it was ok. Adjusted dizzy and it ran ok since.
Offline Khare
« Reply #6 on: 14 May 2008, 11:16 »
thanks
no idea never removed or replaced mine.
dubvrs' advice seems pretty good. Have you tried starting it with the throttle pressed down?
Offline cняis
« Reply #7 on: 14 May 2008, 11:47 »
thanks
yes i've tried this :wink:
it will rev up but stall as soon as the ignition key is returned to position 2. it was suggested i changed the ignition switch, which i have and its still the same.
maybe its a relay or something?
i hate being such a noob!  :cry:
Offline Khare
« Reply #8 on: 14 May 2008, 12:27 »
could be a relay. No idea though. I think you should leave it to the experts. It may cost money but it saves you alot of time and hassle.
Offline cняis
« Reply #9 on: 14 May 2008, 12:30 »
true enough.
i was really hoping it was going to be a simple project, with it running fine before storage.
but currently it is going nowhere and has mot MOT.
PLUS the gear linkages have just gone VERY sloppy all of a sudden...
