Author Topic: Cant get my Air Con to work..ITs toooo Hot!  (Read 3830 times)
Offline DamoGTI
« on: 12 May 2008, 15:03 »
Guys my Gti Aircon wont work... I have the stupid one with ECON on the bottom.
Ive only had the car 3 weeks and its never worked..HAs it got Aircon? Or is it busted do you thinks??
 :sad:
Offline SteveS
  • GTI ED30
Re: Cant get my Air Con to work..ITs toooo Hot!
« Reply #1 on: 12 May 2008, 15:07 »
ECON turns the aircon OFF, its on by default on non uk GTIs' . ECON stands for ECONOMY.
i think....
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline DamoGTI
« Reply #2 on: 12 May 2008, 15:08 »
yea i know. I have tried it switched on and off. On Low, 16, 16.5 and nothing but hot air pumps out.
Offline SteveS
  • GTI ED30
« Reply #3 on: 12 May 2008, 15:10 »
it pumps out hot air even when on "low"? then its fooked! lol
SteveS
Offline Greenouse
« Reply #4 on: 12 May 2008, 16:00 »
If it's not had much use it may just need a service and re-gas. Not too expensive, around the £50 mark and there are usually mobile guys that will come to you.  :wink:
Offline DamoGTI
« Reply #5 on: 12 May 2008, 16:06 »
Hope so. Im skint at the mo! :sad:
Offline 182_blue
« Reply #6 on: 12 May 2008, 16:25 »
i know this doesnt help but mine froze my tits off this AM on the way to work  :laugh:
Phil mcavity
« Reply #7 on: 12 May 2008, 17:09 »
Yes you need to have it re-gas'd, you should use your aircon regular as it will deteriorate the seals in the pump unit if you dont,and will more likely loose gas pressure through lack of use, i run mine daily just for 5 mins and then shut it down or put it onto economy setting.
Offline SiGibbo
« Reply #8 on: 12 May 2008, 17:19 »
Hi
Mine stopped working last week it didn’t make any funny noises just wouldn’t blow cold.
Took it to the dealers and the pulley had sheered off the compressor cost £1200 in parts alone luckily warranty covered it.
TeddyKGB
« Reply #9 on: 12 May 2008, 17:43 »
The air con pump is constantly running (albeit very slowly even when "off") to prevent this.
