Author Topic: door hinges  (Read 1308 times)
Offline forzanerazzurri
door hinges
« on: 25 April 2004, 09:14 »
i seem to be having a problem here with a creaking noise coming from not the door hinge but the metal thing that it grabs onto(on the chassis)  it seems like it has started corroding around and makes a craking npise when i drive over bumps.  it is not solid anymore it moves just a bit and makes a squaking noisem should this be osmehting to worry about as i dont want it to break one day and not be able to keep the door closed
'85 MK2 GTI BIGBUMPERS NeuspeedTurbo/SportSprings,Lowered 2"on15" BBSw/NittoTyres, PortPolish, Bored, 16VThrottleBody, NeuspeedShortShift, DubspeedBigBoreIntake, SwayBar, Racing
Offline richandhazel
Re:door hinges
« Reply #1 on: 26 April 2004, 22:28 »
Do you mean the strike pin? You should be able to tighten it back up........might take a little trial and error to make sure its in the right place mind.
Re:door hinges
« Reply #2 on: 27 April 2004, 03:32 »
well i drove my gti off a cliff, there problem solved.
