Author Topic: plastic arch trims removed  (Read 1709 times)
Offline nelds
  • Now Golfless but owning an Audi still counts
« on: 11 May 2008, 21:46 »
here are some pics of before and after arch removal. i've also fitted the new side trims, just need to get bumpers done now. still don't know whether to colour code bumpers tops and splitter or go with black the same as side trims.....open to suggestions
before
after with driver trims fitted
bloody rust scab
came across this poxy dent.......gutted
Offline Vdubbster
Re: plastic arch trims removed
« Reply #1 on: 11 May 2008, 21:53 »
My arches were messed up slightly so I left the trim on.
Quite like the gloss black but it don't really suit the other black trim, maybe get the rest done the same?
Out of interest Why did you get them sprayed up?
 :wink:
kells
« Reply #2 on: 11 May 2008, 21:59 »
i really do prefere the arches left on...maybe look better if it was lowerd and had the non textured bumpers
Offline nelds
« Reply #3 on: 11 May 2008, 22:38 »
i got them sprayed because i got fed up with cleaning the plastic trim over and over and over. they were textured but had them smoothed and coated with high build primer before top gloss coat was applied. colour code the bumpers or black the tops do you think...???
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 11 May 2008, 22:46 »
I am a fan of the de arched look...... was thinking of sorting mine but still unsure?? and I would try and match the rub strips to the bumpers or full colour code them...
Offline remapped
  • If you are going through Hell, keep going
« Reply #5 on: 12 May 2008, 01:11 »
coming a long good but needs a good slaming sir !!!
in  fact all mk3s do
OEM(ish) G3GTi 8v5dr
Offline nelds
« Reply #6 on: 12 May 2008, 08:01 »
it's on my TO DO list  :smiley:
« Reply #7 on: 12 May 2008, 08:04 »
That dent will take some sorting.
« Last Edit: 11 July 2012, 13:44 by Wayne »
Offline nelds
« Reply #8 on: 12 May 2008, 08:27 »
you didn't replace the corners so it'll look unfinished
Offline eightyeightmph
« Reply #9 on: 12 May 2008, 08:45 »
Nelds, why not colour code the side trims & bumper tops, leave the lower spoilers (front & back) alone though as they just don't look right painted! :smiley:
2016 GOLF GTD
