Author Topic: do seat ibiza cupra turbo brakes fir  (Read 1050 times)
Offline richard s
« on: 11 May 2008, 20:39 »
spotted above car in a scrapyard and thought they would be a good upgrade for my 8v brakes
first off would the hubs fit or are they for a wider driveshaft with it being a turbo if so does anybody know what size discs they are
cheers
Offline Agreeable Slick
  • Unit
Re: do seat ibiza cupra turbo brakes fir
« Reply #1 on: 11 May 2008, 21:04 »
No.
you would need to change everything. Including the hub to get them to fit. They will prob be around the region of 280mm.
oh and they are also 5x100.
Offline Mew
« Reply #2 on: 11 May 2008, 21:53 »
Pretty sure the early 20v turbo ibizas are 4 stud. As far as i'm aware you can just use the later mk2 hubs and use the ibiza callipers and carriers. They are 280mm as slick says.
Offline Dolly
« Reply #3 on: 11 May 2008, 22:29 »
yeh 4 stud 280mm's as are my mk2 ibiza cupra sport.
Offline richard s
« Reply #4 on: 13 May 2008, 22:05 »
they are 4 stud so does this mean that the hubs will fit or would i need to get the hubs from a 16v
and is £50 a good price for the calipers and should they be painted red from factory
cheers
Offline Dolly
« Reply #5 on: 13 May 2008, 22:29 »
£50 is very good, callipers and carriers can fetch up to double that, scene tax ect. you will need to upgrade the hubs, im not 100% sure if the hubs from the 20vt will fit though .
Offline richard s
« Reply #6 on: 13 May 2008, 22:39 »
cheers guys i will have to bob down and see if they are still there
