Author Topic: Rear Wheel Arch trim removal?  (Read 2962 times)
Offline Blackie_No1
  • GTi baby!! woop woop!!
« on: 11 May 2008, 14:33 »
Hey,
How hard is it to remove these?  Will I be able to shave a bit off them to stop my new rear wheels scrubbing?  They are the wrong offset hence the scrubbing  :sad:
'97 8v GTi, Piper S/Steel Zorst, K&N panel Filter, Jamex 40/35 kit & Gas shocks
Offline nelds
  • Now Golfless but owning an Audi still counts
Re: Rear Wheel Arch trim removal?
« Reply #1 on: 11 May 2008, 14:54 »
i've just this second removed all of my wheel arch trims, easy peezy. u need to drill the metal rivets (using a small bit)  then pull them off, u'll need to get some CL or driver trim to replace the corners. if your rims are too bit you may have to have your arches rolled. i found one rust scab and one dent  lurking beneath mine which i need to get sorted
kells
« Reply #2 on: 11 May 2008, 15:30 »
wow getting common is the de arched look, will be rare seeing a gti with them on which is good for people like me  :cool:
Offline eightyeightmph
« Reply #3 on: 11 May 2008, 15:41 »
Me too! :afro:
2016 GOLF GTD
Offline bored_Welsh_lad
« Reply #4 on: 11 May 2008, 16:09 »
me 3
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
kells
« Reply #5 on: 11 May 2008, 16:28 »
hang on a mo, dont us 3 all have black 3's?  :cool: :cool:
« Reply #6 on: 11 May 2008, 16:35 »
Mine are back on so that makes 4
Offline Vdubbster
« Reply #7 on: 11 May 2008, 17:00 »
5
« Reply #8 on: 11 May 2008, 17:32 »
Haha! We'll have to start a Black MK3 GTi owners club! :wink:
2016 GOLF GTD
Offline dubsport
  • TDI POWAR!
