Author Topic: DASH CLOCKS  (Read 886 times)
Offline PS1RST
DASH CLOCKS
« on: 11 May 2008, 12:42 »
I HAVE AN ACCRUCY PROBLEM WITH MY MK2 GOLF CLOCKS.THE MILES PER GALLON IS READING 99.9 CONTINUAS,THE TEMP IS OUT,THE DIGITAL READING IS ALSO OUT.
CAN ANYONE SUGGEST A WAY TO MAKE THEM MORE ACCURATE.
WOULD IT BE THE SENSORS OR THE CLOCKS THEMSELVES.
ANY HELP WOULD BE APPRICIATED THANKS
« Last Edit: 11 May 2008, 13:00 by PS1RST »
Offline Jay
  • balding fat cvnt
Re: DASH CLOCKS
« Reply #1 on: 11 May 2008, 13:02 »
I'd say the clocks were kaput. If you know anyone with the same clocks swap them over and see if it cures it that will tell you for defo.
Offline PS1RST
Re: DASH CLOCKS
« Reply #2 on: 11 May 2008, 13:32 »
Thought it might be thanks for the addvice  :smiley:
Offline Mew
Re: DASH CLOCKS
« Reply #3 on: 11 May 2008, 13:36 »
Clean up the earth normally found on top of the head at the back to the right if you're looking into the engine bay. The 99.9 may also be due to a disconnected/split vacuum hose that goes to the clocks.
Offline PS1RST
Re: DASH CLOCKS
« Reply #4 on: 11 May 2008, 13:44 »
the mpg drops if i floor it but at cruising it risesback up. the earths are all clean
Offline Mew
Re: DASH CLOCKS
« Reply #5 on: 11 May 2008, 14:00 »
COuld still be a small leak in the vacuum hose though. I'd rather give it a go than get some new clocks  :wink:
Offline PS1RST
Re: DASH CLOCKS
« Reply #6 on: 11 May 2008, 14:18 »
just checked the vac pipe in the bay and just pulled the clocks i put a vac tester on in and it dont drop. its a pain i only wont it to work cos its there i like every thing to work as it was intended
thanks for all the help :smiley:
