Author Topic: Stereo fault (sony single disc)  (Read 1145 times)
Offline D Squared
« on: 10 May 2008, 22:02 »
My CD player in my car has packed up...It switches on, displays radio stations etc, but no sound.
1 of the wires that comes out of the back of the stereo, which isn't connected anywhere has ATT written on it?? any ideas if that's needed??
Is there an amp somewhere in a mk3 golf GTi that controls/distributes the sound?
MK3-MK5- Now MK7 GTi
Offline mr.ots
Re: Stereo fault (sony single disc)
« Reply #1 on: 10 May 2008, 23:12 »
The ATT wire is only used if you have a hands free car kit that lowers the volume of the stereo when a call comes in. There aren't any additional amplifiers in the car that distribute the sound to the speakers, it all comes straight from the stereo unless you have had an aftermarket amplifier fitted.
It could be that the amp in your stereo had packed up. Did you do any work on the car just before the sound went?
'97 Twilight Violet Mk3 Golf GTI 8v                              '96 Mystic Blue Corrado VR6 Storm
Offline eightyeightmph
« Reply #2 on: 10 May 2008, 23:15 »
Have you checked the speaker connections, might look connected but not be if you know what I mean?
2016 GOLF GTD
Offline D Squared
« Reply #3 on: 11 May 2008, 09:42 »
thanks for replies, i did no work prior to the sound going on the stereo, and there is no aftermarket amp fitted.
the sound was a little intermittant the day before, then just stopped, everything else works on stereo.
thanks for info on ATT, at least i don't have to worry about that...i'll just have to have a good look at all connections again, but they appear to be connected. when i took it out i was hoping to find a loose speaker connection....
the stereo is a Sony CDX-4180R
« Last Edit: 11 May 2008, 09:55 by D Squared »
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 11 May 2008, 11:06 »
the ATT isnt touching a ground is it?  that will mute it when it touches ground basicly so check that mabey?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline D Squared
« Reply #5 on: 11 May 2008, 13:40 »
Will check thanks..
