The garage
oil pump
Topic: oil pump (Read 1846 times)
dubslug
oil pump
24 April 2004, 08:47 »
how easy is it to replace the pump?? is it in the sump?? if so is it just a case of um bolting it and putting new one in??
1992 pearl grey 8v
richandhazel
Global Moderator
Forum addict
Re:oil pump
24 April 2004, 10:12 »
Hi Rik,
You need to drop the sump and then its simply a case of unbolting.
dubslug
Re:oil pump
24 April 2004, 16:44 »
thanks rich, is it a normal socket or will i need a splined tool??
1992 pearl grey 8v
richandhazel
Global Moderator
Forum addict
Re:oil pump
24 April 2004, 19:46 »
Normal tools.........10mm socket for the sump bolts and 13mm for the oil pump, if memory serves me correct.
golfvr6
Guest
Re:oil pump
24 April 2004, 20:05 »
You will need a long extension bar to get the sump bolts on the gearbox end.
richandhazel
Global Moderator
Forum addict
Re:oil pump
24 April 2004, 20:12 »
Oh yes........they can be a little awkward, well remembered '6
The garage
oil pump
