Author Topic: PLEASE HELP! I've f**ked up my car!  (Read 3722 times)
kells
Re: PLEASE HELP! I've f**ked up my car!
« Reply #10 on: 08 May 2008, 23:50 »
The Earth has been put screwed in to the metal under the seats. It was sanded down to bare metal as well so surely it couldn't be that?
i mean the earths for the rest of the car, you might have moved them or something
Offline Shady Pioneer
  • graphic designer.
« Reply #11 on: 08 May 2008, 23:51 »
No didn't touch any wiring behind the stereo, the only thing I did was plug in the RCA lead and connect the remote lead to the blue connection off of the block of the Alpine one.
  • graphic designer.
« Reply #12 on: 08 May 2008, 23:52 »
Right I see. Bloody hell lol, umm...where are the Earths located roughly on the car?
  • graphic designer.
« Reply #13 on: 08 May 2008, 23:52 »
BTW, do we think it's a wise idea for me to go unplug the power cable from the amp in case it drains my battery?
Offline mat-ryder
« Reply #14 on: 08 May 2008, 23:54 »
it may have nothing to do with the stereo. check wiring in the pas side footwell as it may have been disturbed.
shouldnt drain the batt if the remote wire is connected properly
Offline mush
« Reply #15 on: 08 May 2008, 23:54 »
drivers side below and to the right of the steering wheel. there’s a plastic panel you need to remove that and all the fuses should be visible. from what I remember the description of what each fuse does should be on the back of that panel. check them by pulling them out and looking if the metal strip down the middle isnt broken (don’t get them mixed up)
i would check them first  :smiley:
good luck
MK2 golf 16v :-)
Offline vdub_adz
« Reply #16 on: 08 May 2008, 23:55 »
best earth is the seat belt reel take small bit of paint for better contact
Offline mush
« Reply #17 on: 08 May 2008, 23:55 »
2nd that  :cool:
MK2 golf 16v :-)
  • graphic designer.
« Reply #18 on: 08 May 2008, 23:56 »
I'll look at the fuses first thing in the morning, thanks for the advice, a question though, if some of them have blown and I goto replace them, wouldn't the same just happen?
Offline vdub_adz
« Reply #19 on: 08 May 2008, 23:57 »
in the boot that is. sorri long day in the middle of moving. and no not if u have earthed it propley. so he says lol
