Author Topic: gear box fluid  (Read 1841 times)
Offline dubslug
gear box fluid
« on: 24 April 2004, 08:45 »
wanna change me fluid but how?? and how much will i 1.6 ez engines box take fluid wise?? :-[
1992 pearl grey 8v
Offline richandhazel
Re:gear box fluid
« Reply #1 on: 24 April 2004, 10:20 »
You need a 17mm allan key or the special tool available fairly cheaply at most motor factors.
Off the top of my head I think the capacity is around 2.5 litres.
Offline dubslug
Re:gear box fluid
« Reply #2 on: 24 April 2004, 16:46 »
again thanks for the reply rich, will get that done asap too then
1992 pearl grey 8v
golfvr6
Re:gear box fluid
« Reply #3 on: 24 April 2004, 17:10 »
You will need 2 litres of gearbox oil  :)
Offline dubslug
Re:gear box fluid
« Reply #4 on: 24 April 2004, 17:33 »
best get three incase i spill some, will it make a difference to gear changes?? sometimes a bit crunchy
1992 pearl grey 8v
vwsystems
Re:gear box fluid
« Reply #5 on: 24 April 2004, 18:12 »
yes if you get the synthetic stuff it will help the crunches!
some gearboxes differ on the mount of oil they take so just fill it uo as normal through the fill plug on the side of the box....... once it starts to pour back out its full
just back sure it is full and not just pouring back out because it cant get in the box quick enough........
