Author Topic: Electrical problem?  (Read 1063 times)
Offline ToRo
  • Just because I won't - doesn't mean I can't.
Electrical problem?
« on: 08 May 2008, 22:06 »
When I drive along, and then stop at a junction or lights, my car revs itself then drops dramatically and eventually stalls, this has only started occuring today, and to top it all off my power steering went and then my engine died on the way home from Basingstoke...
The car starts up again first time afterwards... Any ideas?
Have posted this in The Garage too incase someone who knows doesn't read this category.
Offline ToRo
Re: Electrical problem?
« Reply #1 on: 09 May 2008, 06:26 »
UPDATE: I think the problem stems from the heaters, as it only started once I'd put it to 0...
Still don't know :(
« Last Edit: 09 May 2008, 17:38 by ToRo »
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 10 May 2008, 14:17 »
thats to do with your engine management,  thats all i can tell you  :smug:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Pete Taylor
« Reply #3 on: 10 May 2008, 15:15 »
Check your vacuum hoses are still intact, especially check the thicker hose from the throttle body to the carbon cannister hasn't popped out
Offline Kenny_1.6
  • it will be a GTi... some day... lol
« Reply #4 on: 11 May 2008, 08:16 »
could be Relay 30 - ECU relay too, very common problem  :wink:
Men have two emotions: Hungry and Horny. If you see one without an erection, make him a sandwich. :D
