Author Topic: Sportz Blue Bulbs  (Read 1296 times)
Offline martininwillerby
  • Golf GTD DSG
Sportz Blue Bulbs
« on: 08 May 2008, 16:09 »
Another set of Sportz Blue Bulbs fitted.... One more set to go.
The difference between them and the OEM bulbs are amazing...
OEM Yellow fog light...
Sportz Blue fitted to both main beam & high beam...
All together now...
Martininwillerby
Golf GTD DSG, RSN510, DAB, Bluetooth, Leather, 18" Charleston Shadows, Park Assist And In The Best Colour... White.
Martininwillerby
NewGolf
Re: Sportz Blue Bulbs
« Reply #1 on: 08 May 2008, 16:26 »
I have Bi Xenons, so no need to tinker with them, but can I upgrade the lamps in my front fogs to better ones like you have in your main beams? They are yellowish ones on mine as from standard.
Offline indublin
  • "Hotel California" forum.... you can log off anyti
« Reply #2 on: 08 May 2008, 16:44 »
How did you get the fu$%ing bulbs out? :angry: I managed one and still have one yellow bulb! What a twit to get out :sad:
Steel Grey 2006 GTi 3-Door - Monza II's - Tinted Rear Windows - Arm Rest
  • Golf GTD DSG
« Reply #3 on: 08 May 2008, 18:40 »
Easy... or should I say tricky to put back together
Main beam, twist off backing to reveal the inner. Twist off small backing (note direction). The bulb is held by this, replace and fit back (tricky). Fit main backing back on.... Repeat on the other side.
High beam, pull off rubber backing. Stick your head right in so you can see retaining clip / connection. Pull off connection, Unclip clip and lift up, remove bulb ( note position ). Refit bulb, refit clip refit connection and lastly rubber backing...
Hope this helps
Martininwillerby
Martininwillerby
WhiteGTI
« Reply #4 on: 08 May 2008, 18:48 »
Hi Martininwillerby
Could you give me the eBay link for the dipped headlight bulbs that you bought the other week? Think they look pretty good!
Thanks.
  • Golf GTD DSG
« Reply #5 on: 08 May 2008, 21:25 »
This should be it...
http://stores.ebay.co.uk/id=114816043
Martininwillerby
Martininwillerby
WhiteGTI
« Reply #6 on: 08 May 2008, 22:13 »
Thank you! :smiley:
