Author Topic: Bit of a dumb question  (Read 1889 times)
Offline VW_08
« on: 08 May 2008, 15:23 »
Where is the switch for my front fog lights?
Ive only had this car a 7-8 weeks and never needed them but just thought on my drive home from work "where is the fog light switch", had a quick butchers while i was driving and couldnt see nothing to do with fogs?
A pic might help  :laugh:
P.s yes iam being lazy  :grin:
Offline ineson
Re: Bit of a dumb question
« Reply #1 on: 08 May 2008, 15:26 »
Just pull out the switch for the main headlights out towards you and that switches the fogs on.
Pull out once for front fogs and then again for the rear fog lights.
Offline mat-ryder
« Reply #2 on: 08 May 2008, 15:32 »
just to add to this quickley, did all gti's come with front fogs as standard as mine hasn't :cry:
Offline VW_08
« Reply #3 on: 08 May 2008, 15:50 »
A light movement flashes and pulled all the way and let go turns on main beam.
Offline ineson
« Reply #4 on: 08 May 2008, 15:55 »
To the right of the steering column, where you turn your sidelights and headlights on and off, the circular switch.
Pull that out towards you once for from fogs and twice for rear fogs.
Offline Mikester
  • Civic Type R
« Reply #5 on: 08 May 2008, 15:55 »
Should do, maybe the bulbs/fuse has gone?
Offline VW_08
« Reply #6 on: 08 May 2008, 15:57 »
How on earth are you meant to know that? is there a tiny tiny picture or something.
Ill try that later or first thing tomorrow morning when its not so bright outside.
cheers guys
Offline eightyeightmph
« Reply #7 on: 08 May 2008, 16:12 »
Optional extra mate but dead easy to retro fit - that's what I've done! :afro:
2016 GOLF GTD
Offline VW_08
« Reply #8 on: 08 May 2008, 16:18 »
woo optional extra you say, hope mine has them then.  :cool:
Offline ineson
« Reply #9 on: 08 May 2008, 16:24 »
You should be able to tell just by looking at the front of the car.
The 3 lights within the bumper each side are (starting from the inside) fog light/ blanking panel / indicator.
If you look at mine and mikesters signatures you can see the fogs compared to mat-ryders sig where he hasnt.
He has blanking panel / blanking panel / indicator.
