Author Topic: rear brake upgrade  (Read 2755 times)
Offline 1688bran
Re: rear brake upgrade
« Reply #10 on: 10 May 2008, 17:02 »
Calipers, carriers, splash guards, discs and pads
Get them brand new at stoopid money or get them from the following cars
MK1 Leon Cupra
MK1 Octavia VRS
MKIV Anniversary
you can use the ones from the R32 and TT but you'll then need spacers
EDIT - Ridge beat me to it
 im running on 19"s so if i fit the TT brakes will i still need spacers ......? ? ?
Offline linz
  • vee-dub
« Reply #11 on: 10 May 2008, 17:43 »
im running on 19's also !!
and im thinking about the spacers regardless but dont think you have too
Offline richw911
« Reply #12 on: 10 May 2008, 17:58 »
Still need spacers - Because the Audi TT and R32 are 4WD  :wink:
Offline 1688bran
« Reply #13 on: 10 May 2008, 18:29 »
do u know what size spacer do i need ........???
Offline richw911
« Reply #14 on: 10 May 2008, 19:55 »
Yep you will need some 6mm spacers  :wink:
Offline 1688bran
« Reply #15 on: 12 May 2008, 13:15 »
 do u know where i can get the spacer from ...... will i need longer bolts too ???
Offline 1688bran
« Reply #16 on: 13 May 2008, 22:14 »
[/quote
  hi richw911 !   do u know where i can get the spacers and longer bolts from ......
Offline richw911
