Author Topic: Best way to take inside trim off? Wiring related.  (Read 1441 times)
Offline Shady Pioneer
  • graphic designer.
Re: Best way to take inside trim off? Wiring related.
« Reply #10 on: 08 May 2008, 08:25 »
What's a grommet? LOL! And where can I get one?
Offline Pete Taylor
« Reply #11 on: 08 May 2008, 08:38 »
Grommet is the rubber bung through the firewall. There's a good one behind where your coolant expansion bottle to run a live for the amp through which comes out behind the glove box near centra
Offline mat-ryder
« Reply #12 on: 08 May 2008, 12:21 »
Take it out and drill a hole through ut that is slightly smaller than the cable, that way it will still be watertight and protect the cable from chaffing
Offline flex
« Reply #13 on: 08 May 2008, 16:00 »
a bit of advise, run the rca cables down the other side of the car to the power cables, prevents interference :smiley:
Thats probably the reason i get some whining that follows the engine noise in mine! Can only hear it when its down low though.
If i can be bothered i might swap it over.
Offline mat-ryder
« Reply #14 on: 08 May 2008, 22:49 »
I had exactly the same problem in my old driver so since then i have always run the power cables seperate to the RCA
