Author Topic: snapped a caliper bolt  (Read 1030 times)
Offline redders
  • 88 8V GTI, 3dr helios blue
« on: 06 May 2008, 21:03 »
hi folks just took the calipers off the ol girl and the calliper bolt has sheared off with about 10mm sticking out, is it a case off drill and tap it?....bloody things a pain in the arse :angry:
cheers
red
http://i224.photobucket.com/albums/dd162/reddersaj/03052008068.jpg
« Last Edit: 06 May 2008, 21:20 by redders »
Offline stuey
Re: snapped a caliper bolt
« Reply #1 on: 08 May 2008, 08:22 »
You could try an Irwin bolt grip socket on it, after much soaking in penetrating fluid! Man that is one crusty hub.
Offline Simon8v91
« Reply #2 on: 08 May 2008, 11:27 »
as above but also consider heating it hard with a blow torch then grips  :smiley:
Could also try an "easy out" but I have only had limited success with these.
Otherwise I think the answer to your question is yes.  Either drill to a diameter just smaller than the diameter of the bolt and try and chase the remaining thread out with a tap or drill the whole lot out and helicoil .
Good luck  :smiley:
Offline redders
« Reply #3 on: 19 May 2008, 17:43 »
solved this little problem........bigger is better.....so im told
http://i224.photobucket.com/albums/dd162/reddersaj/19052008088.jpg
http://i224.photobucket.com/albums/dd162/reddersaj/19052008090.jpg
thanks for the help people.
red
« Last Edit: 19 May 2008, 17:51 by redders »
