Author Topic: Changing the crankshaft sensor  (Read 993 times)
Offline KingPin
« on: 06 May 2008, 10:21 »
Hey Guys,
Anyone have any idea how to change the crankshaft sensor on a MK3 8v im told its not difficult just need guidance.
Thanks
“Learn from yesterday, live for today, hope for tomorrow.”
- Albert Einstein
Offline KingPin
Re: Changing the crankshaft sensor
« Reply #1 on: 06 May 2008, 16:01 »
Just seen its also called the Crankshaft Angle Sensor or the Speed Sensor  :undecided:
cheers
- Albert Einstein
Offline flex
« Reply #2 on: 06 May 2008, 23:43 »
I only have experience with the 16v engine myself (i guess the 8v is similar) but when i changed mine it was in an awkward spot behind the oil filter. I had to remove the 2 big bolts that hold the starter motor/ front engine mount bracket in place, and also the big bolt holding the front mount itself to gain enough access to it. Once these were removed i dropped the engine down a bit while it was supported on a jack and i was able to undo the bolt that holds the sensor in, its just one bolt with a hex type head on it and it just slides out.
Peice of cake :D yeah.......
« Last Edit: 06 May 2008, 23:44 by flex »
Offline KingPin
« Reply #3 on: 08 May 2008, 14:32 »
Thanks bud.
8v is a smaller lump so someone has said to just take off the oil filter. Fingers crossed it works  :laugh:
- Albert Einstein
Offline AndC
« Reply #4 on: 08 May 2008, 14:44 »
Just done mine on my 8v, exactly as described by Flex was the only way I could do it!
