Author Topic: WINDOWS  (Read 821 times)
DOCKERMEL
WINDOWS
« on: 06 May 2008, 06:56 »
anyone help,my driverside window been playing up, comes down but when you put it up it goes halfway 3times, then down. the 4th time it shuts ok.. now it wont work at all,the passanger side works fine, how do you get the switch out might try swopping the connections to see if its the switch...
Offline eightyeightmph
Re: WINDOWS
« Reply #1 on: 06 May 2008, 08:22 »
It sounds like the mechanism - both my rear ones had this problem, basically the little clip that moves up & down the cable when you press the button is plastic & breaks. When you press the button the cable (inside the door attached to the motor & the window lifter) starts to move & the plastic clip that is attached to the lifter channel catches is it but gets so far & slips, then catches, then slips etc. etc.
You'll probably find it you push or pull the glass it'll go first time!
The plastic but is attached to the lifter channel which I think to buy new comes as a complete mech, motor & all, read EXPENSIVE.
Best bet, & what I did, get down the scrappy & just get the bit you need! The bits the same on all MK3's front & back however the rest of the mech varies.
Take the door card off though & operate the window so you can confirm it is this that's wrong though, hope that helps! :afro:
2016 GOLF GTD
DOCKERMEL
Re: WINDOWS
« Reply #2 on: 06 May 2008, 12:18 »
ok thanks will do when i get a chance.
Offline flex
Re: WINDOWS
« Reply #3 on: 06 May 2008, 23:51 »
Sounds like the window regulator (the mechanism with a metal cable driven by the motor). I had my one go on the drivers side its quite common i think, can get replacement unit for about 40 notes from flea bay.
