Author Topic: Tick over problems on Gti 8V  (Read 1559 times)
Offline chaz_mann
« on: 04 May 2008, 21:28 »
Hi guys, I am a recent purchaser of a Mk2 Gti 8 Valver, and today experiened a problem...
Car was fine after an hour drive over to a friends house, but when I started it again, in neutrul and with the clutch down the rev's were fluctuating between 1 and 2 thousand. When the car got hotter, it got to between 1200 and 2500 rev's.
I have plenty of mechanically minded VW fiend buddies who I shall get to look into it, but was just wondering if anyone has any ideas...
Peace and love, Chaz
Offline dasser
Re: Tick over problems on Gti 8V
« Reply #1 on: 05 May 2008, 10:33 »
clean out the idle control valve first with carb cleaner. :rolleyes:
Offline TRANTER
  • golf mkII gti 8v
« Reply #2 on: 05 May 2008, 13:38 »
yea i second the idle control valve most of the time also if the idle mixture screw is set right as mine was idling fine when cold but once warm he revs sat high. so i waited until it was warm and adjusted it to sit at 900 now te idle is fine
Offline nemmfesta
« Reply #3 on: 05 May 2008, 13:46 »
exactly what i did a few weeks ago spot on mine now!!
Offline Mew
« Reply #4 on: 05 May 2008, 16:17 »
Could also be the blue temp sensor
Offline TRANTER
  • golf mkII gti 8v
« Reply #5 on: 05 May 2008, 16:37 »
is that how you have to reset the ecu on all mk2 golfs
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #6 on: 06 May 2008, 08:00 »
You erase the memory on digifant ECU's by disconnecting the blue sensor wire, whilst the engine is running, then rev the engine past 3000rpm 3 times in succession. But you only really need to do this if you are setting up the engines mixture or timing.
