Author Topic: bugger.. I have a brake problem  (Read 1308 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 03 May 2008, 16:10 »
I have rounded off the rear caliper retainer bolts (the big ones)
They will NOT Budge,  is there a trick to get these off as they are star keys and totaly mushed  :angry: :undecided:
Cheers.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline mush
Re: bugger.. I have a brake problem
« Reply #1 on: 03 May 2008, 17:14 »
i did the same on my old mk3 8v and had to get a welder on it to get em off.
weld a bolt on its tricky but normally the only way.
MK2 golf 16v :-)
Offline Paul86S2
« Reply #2 on: 03 May 2008, 18:02 »
I managed to bang a 15mm socket onto mine and this did the trick
Paul
Offline mark3valver
« Reply #3 on: 04 May 2008, 21:23 »
what you need is a set of irwin bolt grippers, the best specialist tool I have ever used
http://www.amazon.com/IRWIN-394001-Bolt-Grip-Remover/dp/B0000CCXVZ
I have these and the expansion set which in total is over £60's worth but they are amazing
want a pair of raceland buckets with model specific subframes for £150 delivered? go here
http://www.golfgtiforum.co.uk/index.php?topic=83910.0
Offline bored_Welsh_lad
« Reply #4 on: 04 May 2008, 21:29 »
stud extractor tool with a ratchet on it!!!
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline mark3valver
« Reply #5 on: 04 May 2008, 22:51 »
have you used them?
Offline Rmachines
« Reply #6 on: 05 May 2008, 11:30 »
Thats a handy looking piece of kit!  Will have to see if i can get hold of one cheep  :grin:
Offline mark3valver
« Reply #7 on: 05 May 2008, 11:40 »
they are worth the 30 quid for the main set for sure.
Even if you can't get them on straight and you are doing it at an angle they just bite in and get tighter and tighter till the nut starts turning, really good quality too
Offline Rmachines
« Reply #8 on: 05 May 2008, 11:46 »
sweet! they sound like a bit of a nuckle saver actualy,  Are the readily available in local tool shops or is this a bit of a speciality?
Cheers.
Offline bow
« Reply #9 on: 05 May 2008, 11:54 »
i use a stud extractor the 3 roller type works every time for me
