Golf mk3
hardmonkeys
Ignition coil
Topic: Ignition coil (Read 962 times)
admc6
Ignition coil
02 May 2008, 15:52 »
Does anyone know if a dodgy ignition coil would cause erratic revs and stalling?
DazVR6
mk3 VR6...FEEL THE GRUNT.
Re: Ignition coil
02 May 2008, 19:59 »
Tis possible but would first look at cleaning throttle body, relays 30 and 167 aswell as replacing vac lines.
Oh and crankshaft position senser.
AndC
Re: Ignition coil
02 May 2008, 21:53 »
And the Hall Sender
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
Re: Ignition coil
02 May 2008, 23:36 »
or the........ (list could go on for ages)... try the clean throttle body, checking and replacing dodgy vacum/breather pipes and relays first... and give vag-com a go before swapping sensors
admc6
Re: Ignition coil
03 May 2008, 10:47 »
Thanks for the ideas. The only thing that hasnt been done is looking at the breather pipes.
I will give that a go today
Kenny_1.6
GTI forum regular
it will be a GTi... some day... lol
Re: Ignition coil
03 May 2008, 13:11 »
if it was a vacuum line or breather pipe, will it show up on vagcom?
Men have two emotions: Hungry and Horny. If you see one without an erection, make him a sandwich.
Mikester
Forum addict
Civic Type R
Re: Ignition coil
Reply #6 on:
03 May 2008, 13:16 »
Quote from: Kenny_1.6 on 03 May 2008, 13:11
VAGCOM can only tell you if a sensor is faulty, but the sensor that is faulty could lead you to believe it was the pipes
admc6
Re: Ignition coil
Reply #7 on:
03 May 2008, 14:07 »
I have had a look at all the pipes and they seem ok
Was just reading through the haynes manual and misfires seem to point to the coil or the distributar and ht leads
Golf mk3
hardmonkeys
Ignition coil
