Author Topic: steering hard in the rain  (Read 1473 times)
Offline lee_lee08
  • 1996 GTI 8v
« on: 01 May 2008, 14:17 »
Went round a roundabout the other day and my steering just would not let me complete the turn. it just locked up and went hard, tried my upmost to avoid a van waiting for me to exit the roundabout.
I heard this is a common fault with golfs in the rain. apparently the PAS belt gets wet and slips slightly causing this to happen?
Is this true and is there anything that can be done to resolve this?
any info is greatly appreciated.
Ta
Offline lee_lee08
  • 1996 GTI 8v
Re: steering hard in the rain
« Reply #1 on: 01 May 2008, 14:18 »
and the belt squeeks alot when wet too! Ive just had my cambelt done and fan belt and PAS belt was changed at the same time. I know its on tight, but could it be too tight?
Offline Horney
« Reply #2 on: 01 May 2008, 14:23 »
You can get a splash guard that helps protect the belt from getting soaked.
Nick
Offline bored_Welsh_lad
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline mark3valver
« Reply #4 on: 01 May 2008, 16:17 »
mine has done this before!!! bloody dangerous tbqfh.....
all of a sudden loose power steering half way round a turn.... :shocked:
want a pair of raceland buckets with model specific subframes for £150 delivered? go here
http://www.golfgtiforum.co.uk/index.php?topic=83910.0
Offline Horney
« Reply #5 on: 01 May 2008, 16:19 »
A mate of mine recently wrote his off due to this very problem. Went straight on and down a bank :-(
Nick
Offline Len
« Reply #6 on: 01 May 2008, 16:29 »
You just have to replace the belt! simple.
www.sas.org.uk
www.the-ace.org.uk
Offline lee_lee08
  • 1996 GTI 8v
« Reply #7 on: 01 May 2008, 16:37 »
well then wont the new belt have the same problem?
Where can i get a splash guard from? expensive???
Offline lee_lee08
  • 1996 GTI 8v
« Reply #8 on: 01 May 2008, 16:40 »
and the current PAS belt is only a month old! if that
Offline boneybradley
  • Back in a Mk3...
« Reply #9 on: 01 May 2008, 17:11 »
try and tighten the belt if its new...worked on mine and i dont have the rain cover!
