Author Topic: Forge D.V Valve fitted.  (Read 3563 times)
Offline CHRIS-M07GTI
« on: 01 May 2008, 00:47 »
After having my Gti Revo chipped some 3 months ago,decided to have a Forge dv fitted today.Had a call from Revolution performance centre in Gateshead to say they had a cancellation and did i want the done early,so its fitted,and have to say,done a ex job,holds boost longer and also have peace of mind,although the original that i kept looks in ex cond also,14,000 mls on the clock,3,000 revo'ed!!!
£170 all in,is this a good price?
Also looked into brake upgrade,and have found motorsport world Tarox G88 grooved disks,Corsa fast road pads,all for £315,but revolution will do for £300 and when on the job,will fit my supplied braided hoses and decent dot 4 brake fluid for £390,not bad me thinks :smiley:
Hel hoses did some great stainless hoses for my Suzuki GSXR 1000K5 at a great price,now they tell me they are doing hoses for cars starting today,much cheaper than goodridge,and stainless ends as standard,so will let all know a price when i order.
If you can afford the cream of the cream brakes like Red Robin go for it,but i think the above is a very good start and price over standard brakes,as i know a few of us could do with slightly better.Bloody roundabouts and corners come up quick these days!!! :laugh:
Offline Hurdy
Re: Forge D.V Valve fitted.
« Reply #1 on: 01 May 2008, 12:17 »
Hi Chris,
£170 isn't a bad price for the DV and fitting.
I'd have thought that for the little extra in price you would have been better going for some 5.1 dot brake fluid over the 4. :wink:
I know what you mean about corners coming up too fast :evil:
Seat Leon Cupra Black 290 DSG
« Reply #2 on: 01 May 2008, 19:57 »
Cheers for the reply Hurdy,will a good brand Dot 4, not be better for the road as it absorbs less moisture,but Dot 5.1 has a higher boiling point,but will need bleed more as for grabbing the moisture,i.e on the track??
Need to get my old books out!!!!
Chris.
Offline Hurdy
« Reply #3 on: 01 May 2008, 20:51 »
With my "enthusiastic" driving style I'd tend to opt for the 5.1 fluid. There are some race fluids that are still classed as dot 4 and perform higher than 5.1 dot, so it can depend more upon the make of fluid you choose as much as the dot rating. :nerd:
Offline 182_blue
« Reply #4 on: 01 May 2008, 20:55 »
Chris.
thats what i remember, 5.1 would need changing more often
Offline martininwillerby
  • Golf GTD DSG
« Reply #5 on: 02 May 2008, 09:51 »
CHRIS-M07GTI... The DV you had fitted the other day was it the standard blow-off or the variable blow-off type, as I've just rang my local VAG approved garage (Ricci Concept, Hull) and have been quoted £65.80 for the DV and £52.88 for fitting (standard forge DV). I have rang Awesome and have been quoted £48.86 and £58.16 respectively for the same. The variable DV is £120ish plus fitting at Ricci Concept.
Ricci Concept have just rang me back and they have one in stock and will be fitting it today at 2pm.
I will report back later today after fitting to give you my opinion.
Martininwillerby
Golf GTD DSG, RSN510, DAB, Bluetooth, Leather, 18" Charleston Shadows, Park Assist And In The Best Colour... White.
Martininwillerby
  • Golf GTD DSG
« Reply #6 on: 02 May 2008, 10:13 »
CHRIS-M07GTI... Me thinks you've had a Replacement Vacuum operated Valve for VAG 2.0 FSiT fitted and not just the blow-off spacer which gives nothing but a woooosh.
In that case it is a good price as forge list them at £155 plus fitting.
as opposed to the Forge DV blow-off spacer for £55 plus fitting
So does that mean when people with remaps say that they've had there DV change they mean the Replacement Vacuum operated Valve and not the blow-off type.
Ha ha... got it now
Martininwillerby
« Last Edit: 02 May 2008, 10:17 by martininwillerby »
Martininwillerby
« Reply #7 on: 02 May 2008, 10:18 »
Hi Martin,mine fitted was the Forge FMDVFSITV,the one recommended on the Forge website.
£114.89 for DV, £29.79 fitting, Net =£144.68  Vat £25.32  Total £170.00.
As Hurdy said,decent price,so im happy with info from guy's who have had work done,i think it's good that we all keep each other informed of prices up and down the country,as i know companies have a buisness to run,but nobody likes to be ripped off!!!
I know Cass will prob use similar companies to me and vise versa with been in the sunny north east,but keep a tab on Hurdy and TT in Yorkshire,Phil Mc on the French Riviara!!!! (Phil needs a ED30 with the air con on all the time in that heat,zaps the power!!)
so prices will vary.
Chris.
« Reply #8 on: 02 May 2008, 10:21 »
I dont want no god dam WHOOOOOOSH,im 37 for god's sake :laugh:
Chris.
Offline 182_blue
« Reply #9 on: 02 May 2008, 10:30 »
^^i wouldnt either, i assume the Forge doesnt give the whoosh unless you get that spacer ?
