Author Topic: Fitting a New Radiator on a GTi - helpful pointers please?  (Read 1003 times)
Offline eightyeightmph
So I've got a nice new OEM Radiator from VW & 3 ltrs of G12....
What's next?
The front end will be off the car over the weekend anyway so what I need to know is where to disconnect the old one, where/how to drain the system etc.
Any pointers please?
:afro:
2016 GOLF GTD
Offline Paul86S2
Re: Fitting a New Radiator on a GTi - helpful pointers please?
« Reply #1 on: 29 April 2008, 09:41 »
Front bumper and crossmember need to be removed. Dont forget to disconnect the wiring for indicators fog lights and temp sensor. Disconnect battery first of course. Headlights will need to be removed or undone and pushed out of the way.
If you are draining the whole system then disconnect the hose at the thermostat.
Disconnect the radiator top and bottom hoses, and the electrical connection for the temp switch/sender.
Undo the 4 bolts holding the radiator on and remove it.
Installation is the reverse of the above. Use new clips on the hoses.
Fill the system slowly whilst squeezing the hoses to expell the air. Took a while to bleed my system properly.
Run the car and check water level, fan operation and temp.
Paul
« Reply #2 on: 29 April 2008, 12:36 »
Great stuff, where did you get the clips from? VW?
2016 GOLF GTD
Offline Paul86S2
« Reply #3 on: 29 April 2008, 13:05 »
No I ditched the VW clips and used standard hose clips from Halfrauds, just don't overtighten them on the plastic pipes.
Paul
« Reply #4 on: 29 April 2008, 21:28 »
Great stuff, thanks! :afro:
2016 GOLF GTD
Offline nelds
  • Now Golfless but owning an Audi still counts
« Reply #5 on: 30 April 2008, 07:02 »
i managed to remove my rad without touching the headlights, you should get away with leaving them and jst doing what he said ^^^^^. my system took about 20 - 30 minutes to re-fill with squeezing the hoses with the filler cap off.
