Author Topic: Wheel alignment  (Read 1371 times)
Offline Jamm89
  • Mk4 GTI 2ltr 3door Black
Wheel alignment
« on: 27 April 2008, 20:02 »
I have recently fitted coilovers on my mk4 golf and i have been advised to get my wheels aligned due to camber and tracking.
Is this normal after fitting coilovers?
cheers
Offline topher
  • Administrator
  • fully functioning
Re: Wheel alignment
« Reply #1 on: 28 April 2008, 08:48 »
yep, some people don't bother.. and then wonder why the coilovers made their handling worse
Offline Len
Re: Wheel alignment
« Reply #2 on: 28 April 2008, 08:52 »
And also why their tyres wear out and scrub!
www.sas.org.uk
www.the-ace.org.uk
Offline Khare
  • The bear that khares
Re: Wheel alignment
« Reply #3 on: 30 April 2008, 16:14 »
yup this is all true. I fitted coilovers last week and im booking in a sesion to align all the wheels and set camber. I was quoted around £50.
Offline Mooby
Re: Wheel alignment
« Reply #4 on: 01 May 2008, 16:09 »
Yup.  In fact you should get it done after any work that involves disconnecting the suspension arms and suchlike.
Don't know about on a Mk4, but on a Mk3 There is some degree of adjustment available at the front for camber/tracking, but none at the back.  Most alignment places will check the back anyway, but can't change anything.
I was pissed off with the last time I got mine done (ProTyre in Bristol).  I specifically asked for the camber to be set on the lower tolerance (so I had a bit of negative camber, but not too much) and they didn't (in fact it was set closer to the upper tolerance), and I had a steering-wheel that was obviously not centered so they must have not clamped it.  I would've had a whinge at them but I was last in and they were closing when I picked up the keys...  so I've just resolved not to bother going to them again.
Sold the VR6... Now officially An Old Man With A Passat Estate.  At least it's a 1.8T :grin:
Offline Jamm89
Re: Wheel alignment
« Reply #5 on: 16 May 2008, 18:27 »
Just picked mine up from graham goode in leicester after a lazer wheel alignment. £100 lighter and told that they couldn't adjust the back anyway
