Author Topic: Anyone in Essex.. Hall sender  (Read 665 times)
Offline leegt5
« on: 27 April 2008, 17:39 »
Still got the holding back problem and have ruled out the following
Cat... Changed
Oxygen Sensor.....Renewed
MAF.....Changed
Throttle Body.....Changed
Fuel filter.....Changed
Coolant temp sensor.....Changed
Air filter.....Changed
Plugs.....Changed
Dizzy Cap....Changed
Rotor Arm....Changed
Compression...... All Cylinders fine
Revs past 5k...... Timing is spot on
Im sure theres other things that I have forgot..
Gets worse onces warmed up !!
And not showing any faults with vagcom but when I go to measuring blocks and go to Hall sender operation conditions the code in showing 00010000 which equates to the Hall sender requires adaption.
What I want to know is, is this normal to say this or do I have a problem with the hall sender ??
If anyone is local to Romford with an 8v with AGG engine, would I be able to come to you and plug in Vagcom and see if yours shows the same then I know it is not this before I spend any more money in vain !!
Cheers in advance
LEE
