Author Topic: Had my ED30 on Awesome rollers today...  (Read 13349 times)
Offline neg
Re: Had my ED30 on Awesome rollers today...
« Reply #40 on: 28 April 2008, 10:02 »
Nice power figures, what settings are you running?
Offline markymark
« Reply #41 on: 28 April 2008, 10:33 »
My mate does a lot of maps for various tuning houses and has said he will do mine for nothing. He used to work for AmD and other big names, im very tempted by this now. His web site is www.dnatuning.com and what is even better is that he lives 2 minutes away from me!
Offline Vtec Abuser
« Reply #42 on: 28 April 2008, 11:34 »
Running Boost 8 Timing 5 mate.. I was told (even though I always use 99 ron) that timing 5 is about as high as I should go, as when the weather starts to warm up (eventually  :undecided:) it may start pinking if I go any higher. Will have a play about when I get my Select + switch in the next few weeks and see..
Candy White Ed30 3dr DSG, Nav, Bi-Xenons, Armrest, MFSW...
Offline SteveS
  • GTI ED30
« Reply #43 on: 28 April 2008, 11:37 »
you can adjust all that urself?
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline Vtec Abuser
« Reply #44 on: 28 April 2008, 11:57 »
Yes mate, son long as you have one of these..
http://www.revotechnik.com/products/sps.aspx
Offline SteveS
  • GTI ED30
« Reply #45 on: 28 April 2008, 12:19 »
looks very simple, one knob? do you program it on your pc or something :s
how much does that cost then!!!!
SteveS
Offline Vtec Abuser
« Reply #46 on: 28 April 2008, 12:30 »
Haven't used the new one yet, so not entirely sure mate. But the previous one had two knobs and was very easy to use.
They are normally £250 + the dreaded, but you can get them a lot cheaper 2nd hand..
Offline Vtec Abuser
« Reply #47 on: 08 May 2008, 14:53 »
Awesome have finally put up our vids and graph from the other weekend if anyone's interested..
http://www.awesome-gti.co.uk/rollingroad/rr.scn_260408.html
Graph..
Offline neg
« Reply #48 on: 08 May 2008, 18:26 »
Switch is easy to use, little bit better than the older versions as you can use the new one to read the values off the car - I always used to forget.
The main bits on the new one is setting A B & C, you can pre-set 3 different settings into the unit for fast switching or connect up through a laptop (USB) and alter your settings that way.
I run 6/6/9 on an everyday basis (Non Ed30 mind), when playing with the settings its always best to do some logging to make sure the CF values are not too high.
Offline Kiddfrost
« Reply #49 on: 11 May 2008, 20:39 »
Mine's a non ed30 too, can you "aquire" your settings from the ecu? I've tried and can't do it with my sps+. I contacted Revo and they said sps+ will only aquire the settings from certain ecu's  :huh:
