Author Topic: another temp warning question  (Read 1180 times)
Offline raferackstraw
« on: 26 April 2008, 12:59 »
hi have done a search and found some answers but need pointing in right direction
temp warning light flashing after warm up, coolant level is ok and  fan cuts in as usual no overheating at all
now i took out level sender and cleaned it up and shorted out wires to see if light still flashed and it still flashes
temp guage works fine so i dont think its the sensor in the block
could it be the instrument cluster itself?
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Re: another temp warning question
« Reply #1 on: 26 April 2008, 14:32 »
right further to above checked for airlocks and run wiv cap off until it boiled over topped up and left running fan kicks in ok heater works fine
still engine does not overheat so im now thinking its a wiring or instrument cluster fault is there a dedicated relay for level sender?
light flashes on ignition and goes out when started but when temp needle gets to 1/4 it starts flashing
or if engine is fully warm and you switch off and restart light goes out temp needle rises to 1/2 and about 30secs later warning light starts flashing again
bl00dy wind up its never happened before  :shocked:
