Author Topic: two gti's. how come dizzys position r diffrent  (Read 1070 times)
Offline dubmad
  • dubs all the way
« on: 25 April 2008, 14:48 »
my mates golf and now mine  can someone please help me as im havin abit of trouble with mine, and i think this is y .think dizzy timing is out is that the case ?
« Last Edit: 25 April 2008, 15:52 by dubmad »
http://
Offline boneybradley
  • Back in a Mk3...
Re: two gti's. how come dizzys position r diffrent
« Reply #1 on: 25 April 2008, 15:50 »
the brown cap one is bosch and the other with the black cover looks like the alternate lucas type..... simple answer...different dizy's
Offline dubmad
  • dubs all the way
« Reply #2 on: 25 April 2008, 15:58 »
caps are but dizzys the same.  im lookin at no1 plug and hall sender surly they should be positioned the same
http://
kells
« Reply #3 on: 25 April 2008, 16:37 »
mine is a bosch but its not red / brown, mine is black, deffo bosch as it says so on the top!
  • Back in a Mk3...
« Reply #4 on: 25 April 2008, 16:45 »
if the caps are different the dizzy's are very different!          if i remember correct the sparking order is the same but no1 is in a different position? ensure your cap fits correctly as they both will fit but there are lugs on them and the cap should be mounted strongly and not move in any way!  i have come accross the wrong caps being used and these cause loads of trouble...
and here's mine (missing the black splash cover!! that vw fitted to complicate things!!) and you can see my hall sender on the right of the pic with the plug on...
kells
« Reply #5 on: 25 April 2008, 16:51 »
yep mine has the blach bosch splash cover!!, red under it i notice
  • Back in a Mk3...
« Reply #6 on: 25 April 2008, 16:54 »
i have one but my leads don't fit as well with it fitted!!  oh yeah looking at that pic...i must clean the engine!! kells you'd be having heart murmours with all that dirt!  :wink:
kells
« Reply #7 on: 25 April 2008, 17:20 »
hahahahhaa heart murmours hahahaha like it :grin:
Offline dubmad
  • dubs all the way
« Reply #8 on: 25 April 2008, 18:42 »
just sorted it out . the dizzy ad to be repositioned, so now they both pointing the same way. and it runing much better.dam the previous owners should be shot.if it was a ford it would of been scraped, but you cant do that to a vw can you.  and i removed the black cover as it just confuses the issue.  thank ya all for you help
http://
