Author Topic: Stock ECU on a 1.8t mk2 swap?  (Read 1286 times)
Offline dirty
« on: 24 April 2008, 21:16 »
Before i start i have used search but havnt found what i need to know so if you have a link then paste it in for me, thanks
So another question how much work needs to be done to the donor 1.8t ecu and loom for it to work on the mk2 im swappin it into? I have to defeat the immobiliser i know but can the loom be modified in such a way that it will work?
The reason i want to do this is because if im getting a complete donor car it will keep budget down to use as much as possible rather than throwing it away?
thanks in advance
Offline 20v
Re: Stock ECU on a 1.8t mk2 swap?
« Reply #1 on: 24 April 2008, 21:23 »
qpeng if you send them the engine loom they will modify it so it fits to the mk2 loom wiv ecu bout £600
Offline richard s
« Reply #2 on: 24 April 2008, 21:58 »
if you have a look on uk passats forum a guy called oldskoolperformance fitted a 1.8t from a octavia vrs and he modified the loom to bypass the imob
try to contact him to see if he can give any help
Offline Mew
« Reply #3 on: 24 April 2008, 23:01 »
There is someone with that user name on here too. I think.
Offline cняis
« Reply #4 on: 25 April 2008, 12:52 »
yes its the same guy  :wink:
Offline neo-golfmk2-cy
« Reply #5 on: 11 May 2008, 15:46 »
can i chip my 18 16v ecy? if yes how?
Offline Mew
« Reply #6 on: 11 May 2008, 15:49 »
Nope
