Golf mk3
hardmonkeys
Door hinges
Topic: Door hinges (Read 968 times)
Morris_Gti
Door hinges
24 April 2008, 20:01 »
The door hinges seem to have dropped on my drivers side door and has been letting air whistle through when going more than about 40 and is really annoying!!! Is this a common problem and does anyone know where i could get some new ones?
golfmk31993
Here all the time
Re: Door hinges
24 April 2008, 20:25 »
i have got the same problem,
someone told me to adjust the striker plate wich i have tried, the door sits more flush than it used to but i still get windnoise, the door seal looks fine to me,
any ideas??
Morris_Gti
Re: Door hinges
24 April 2008, 21:42 »
I think the pin might have just rounded off at the bottom over time on mine and just let the door sag a little but im not sure where to get some new hinges from
dubmad
GTI forum regular
dubs all the way
Re: Door hinges
25 April 2008, 18:57 »
its the pins in the hinges they were down as this is common .i got same problem and i intend to sort it monday hopefully .its a main stealer part. but im going to try and fit passinger side pins first as i been told they will fit. i will let you know if it works..
http://
Pete Taylor
Re: Door hinges
26 April 2008, 15:29 »
Yup common problem, more common on 3 doors as the door is heavier. Get them from the dealers, you buy them in half hinges (they aint cheap though)
gtiscott
GTI forum regular
Re: Door hinges
26 April 2008, 16:05 »
there not to expensive, about £12-£15 for a pair if i remember right
Pete Taylor
Re: Door hinges
Reply #6 on:
26 April 2008, 16:09 »
I seem to recall them being £14 per half hinge
gtiscott
GTI forum regular
Re: Door hinges
Reply #7 on:
26 April 2008, 16:42 »
you could be right, i phoned the stealers and thought the guy said per pair but didn't get round to buying them
Mikester
Forum addict
Civic Type R
Re: Door hinges
Reply #8 on:
26 April 2008, 18:03 »
Mine make this wind noise, but they dont look like they have dropped and the seals look fine, or am i being a bit blind?
Golf mk3
hardmonkeys
Door hinges
