Author Topic: split hose, but what is this for  (Read 1768 times)
Offline gtiscott
« on: 24 April 2008, 18:38 »
noticed today that the hose at the top of the picture has split, what is this hose for? and is it easily replaced?
cheers
Scott
Offline dubmad
  • dubs all the way
Re: split hose, but what is this for
« Reply #1 on: 24 April 2008, 18:59 »
cant realy make it out. but it looks like brake sevo pipe. or where does it go to.
 is it a gti
http://
Offline gtiscott
« Reply #2 on: 24 April 2008, 19:08 »
sorry, heres a better pic
Offline dubmad
  • dubs all the way
« Reply #3 on: 24 April 2008, 19:16 »
.only know 8v's off hand.sorry never owned 16v.  but its still looks like a brake servo pipe to me thou  can you see where it goes to then?
http://
Offline gtiscott
« Reply #4 on: 24 April 2008, 19:51 »
you can see on this picture where it goes
scott
« Last Edit: 24 April 2008, 19:58 by gtiscott »
Offline Paul86S2
« Reply #5 on: 24 April 2008, 20:03 »
Its the pipe giving vacuum from the manifold to the brake servo. Coonection at manifold end is a rubber elbow with hose clips which is easily accesible, cant see the connection at the brake servo end, could be difficult to get to.
Paul
Offline gtiscott
« Reply #6 on: 24 April 2008, 20:04 »
does it affect the brakes? :shocked:
Offline Paul86S2
« Reply #7 on: 24 April 2008, 20:08 »
if its splits all the way through you will lose servo assistance on the brakes which will mean you will have to push the pedal a lot harder to get them to work.
Looks like its a push fit into the servo, so as long as you can get your hand in there it should be easy to replace.
Paul
PS sort it sooner rather than later
Offline gtiscott
« Reply #8 on: 24 April 2008, 20:18 »
i will get it tomorrow hopefully :smiley:
Offline gtiscott
« Reply #9 on: 26 April 2008, 21:00 »
getting this part on monday, hope its an easy swap
