Author Topic: anyone know what this error code means or whats faulty?  (Read 1651 times)
Offline bling
p0234 turbo charger overboost condition control limit exceeded.
thanks
Komenda
Re: anyone know what this error code means or whats faulty?
« Reply #1 on: 24 April 2008, 17:35 »
The ECU can't control the boost within its target range. Could be a Vacuum failure. Could be a line fail or the DV could be stuck open. Even be a dodgy solenoid not activating properly.
Offline Hurdy
« Reply #2 on: 24 April 2008, 17:52 »
Could be a blown DV too. :sad: :cry:
Seat Leon Cupra Black 290 DSG
Offline bling
« Reply #3 on: 24 April 2008, 19:36 »
i did complain to the stealers aout the lack of performanve i thought the car had and they told me after they test drove the car it was bang on!
now i think there is some problem for sure.
Offline bling
« Reply #4 on: 30 April 2008, 10:55 »
Booked the car in with dealers and they said that the code relates to the Dump valve or the divertor valve its known as.
had it replaced and it has instantly made a big difference to the fuel ecomnomy and i find the car is holding the boost much better now.
if you can here a whooshing noise which wasn't there before then more than likely your dv has split.
worth while getting it checked out.
Offline 182_blue
« Reply #5 on: 30 April 2008, 11:06 »
How old is your car ?, and is it normal GTi
Offline bling
« Reply #6 on: 30 April 2008, 11:44 »
mines a 05 plate and its a normal gti.
Offline joesgti
« Reply #7 on: 30 April 2008, 12:06 »
probs a split dv if its an 05, 05 out of warrenty yet?? mine is!! id get down there asap as your warrenty might run out any day.  :lipsrsealed:
GTI MK5
Not the only GTI...........but the best! ; )
