Hi everyone,
I have been having real problems with my '96 GTi 8v
It cuts out and the oil light flashes, it has been getting progressively worse now it won't even go 50 yds without dying!!
I replaced the Crank sensor which worked for a short while but then it cut out again so I replaced the ECU power relay (No. 30) and that worked for even longer, about 150 miles, then it cut out again!.
I was going to replace the Hall sensor next but it isn't giving as a fault code on the diagnostics (even when the car is broken down!), what is also strange is that when the car is running I can unplug the hall sender and it makes no difference!. Also the No. 30 relay that I replaced seems to be very hot!, also the relay No. 36?? seems to 'click' when the car cuts out but I'm not sure what this one is!
The problem is I've spent so much on it recently that I don't want to keep going, I have done thew cambelt and full service new brakes new exhaust and now this!, the car has done 150,000 miles and I have a 50 mile trip to work everyday!!
Time for the scrapyard???
