The garage
Rear brake caliper carrier bolts
4
5
6
Topic: Rear brake caliper carrier bolts (Read 16935 times)
Veedubgt18v
Guest
Re:Rear brake caliper carrier bolts
Reply #20 on:
22 June 2004, 19:43 »
yeah gaybar isnt the word. shocks and brakes on a mk2 is a piece of piss just time consuming. im gonna do the fronts (shocks and brakes) 2moro and top mounts
Veedubgt18v
Guest
Reply #21 on:
22 June 2004, 19:46 »
oh yeah the only thing is that the brakes have to be pumped to pick up the slack on the rear calipers or your handbrake wont work
Veedubgt18v
Guest
Reply #22 on:
i did screw them in all the way tho
golfvr6
Guest
Reply #23 on:
How long do you reckon it will take?
Veedubgt18v
Guest
Reply #24 on:
22 June 2004, 19:48 »
gonna do it all at once so prob an hour each side for the brakes and prob an hour or so to do the shocks prop[erly. thats if it all comes apart frst time. maybe 4 - 5 hours all in
golfvr6
Guest
Reply #25 on:
22 June 2004, 19:50 »
You got all the tools?
Veedubgt18v
Guest
Reply #26 on:
22 June 2004, 19:54 »
yeah all except a caliper wind back tool but i got a g clamp i have used before. got spring compressors to
golfvr6
Guest
Reply #27 on:
22 June 2004, 20:05 »
The nut on the top of the suspension in the engine bay can be awkward.
A g-clamp is fine for front calipers.
I take it you use the wind back tool for the rear calipers.
Veedubgt18v
Guest
Reply #28 on:
22 June 2004, 20:10 »
oh yeah i was gonna ask you if i can borrow the notched tool for undoing that nut. i got one but dont yet know if it fits. the rear calipers you have to screw back in with angled pliers
but i screwed the piston round and round then pushed it back by hand, i kept doing that till it was flush with the housing
Mixologist
Guest
Reply #29 on:
22 June 2004, 20:13 »
Apart from a job well done, i won't mention him starting the car to pump the brakes, with it still in gear, on axle stands
Oooooooo-soooooo close to it falling back onto the reart axle, and me!!!
4
5
6
The garage
