Author Topic: my wind screen wipers dont work  (Read 675 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 24 April 2008, 12:23 »
 :shocked: U cant get them to work!  The fuse is ok!,  Is there a common fault on these i should be looking for ? cheers.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline adyh
Re: my wind screen wipers dont work
« Reply #1 on: 24 April 2008, 13:13 »
Hmm , none that i know of ,check the relay gets power and is working
Offline Rmachines
« Reply #2 on: 24 April 2008, 13:14 »
Ok i have investigated it.. a bit
The fuses is fine.. the X contact relay is ok, i have changed it and the Main Intermitant controll relay is ok... Also the wipers work fine on Full speed.  This made me think Switch.. but i can here the relay click when i select diffrent speeds etc..
Does any one know if there is a controller on the motor?  If so i guess thats my problem.  I will swap it with my other one if it is.  :smiley:
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 24 April 2008, 14:32 »
swap the switch...these are fairly common to go faulty and normally show up with the smallest ammount of smoke!!
