Author Topic: Juddering  (Read 2236 times)
Offline mash
Juddering
« on: 20 April 2004, 16:53 »
When in 1st or 2nd gear giving it only a little gas the car seems to judder as if its going to eventually stall. By giving it more gas it seems to be fine.   Its a 1.8T.
Any ideas?
Offline richy
  • neeeeeeeowm
Re:Juddering
« Reply #1 on: 20 April 2004, 22:35 »
Has this only just started happening?  Is this car new to you?
The Mk4 is a heavy beast and needs a bit more juice than many other cars I've driven to get off the mark. (Sorry if you've had this car for ages-  I don't mean to sound patronising!  ;))
Rich
54-plate Golf 2.0 FSI GT.  Leather interior.
Offline mash
Re:Juddering
« Reply #2 on: 22 April 2004, 08:41 »
This has just started happening a week ago,  the car is on an X plate, 2001.
Just recently when coming to a standstill in neutral the car would cut out intermittently.
Offline D Owen
Re:Juddering
« Reply #3 on: 22 April 2004, 09:04 »
A friend of mine had the same problem with his MK4.
It could be the air flow meter - this solved the problem but was expensive (about ?200)
Before you get an air flow meter try replacing the ht leads and spark plugs.
Tell us how you get on
Offline mash
Re:Juddering
« Reply #4 on: 22 April 2004, 13:10 »
Cheers, will give it a go.
Offline antgti
  • 130PD Gti with Van aaken chip to 165 has now gone,
Re:Juddering
« Reply #5 on: 22 April 2004, 22:46 »
might be worth checking plugs, may be hesitating a bit.
Air flow meter is a good un, I have'nt taken a golf air flow meter apart yet, but if like all the others i have seen from other cars take the gauze out as it restricts airflow.
Also check the idle speed control valve if there is one on 1.8t, these are common problems for the symptoms you describe,
Or sale it and buy an R32, any excuse!!
Me old diesel was quick/........
16.004 sec Qtr mile @ 85mph 23/5/04 Santa Pod
Now running around in soon to be REVO'd Seat ibiza 1.8T 20v FR and missing the fuel economy..............
