Author Topic: Steering problem - HELP!!  (Read 892 times)
Offline Greg
« on: 23 April 2008, 10:35 »
My mk3 16v has a steering issue which i want fixed. Its easier to turn the wheel left than right. By that i mean that on a straight bit of road, turning the wheel to the right takes almost twice the effort than to turn it to the left. This has always been the case since i bought the car, its NOT affected by wet weather. I have lowered the car and had the geometry and tracking done afterwards. I still have this 'easier to turn left problem'.
I replaced the ps belt when i changed the cam belt last year, but it made NO difference.
What should i check next  :sad:
'99 Mk4 1.8T - FMC007p - R-Tech Stage 1 | '97 Mk3 16v | '91 Mk2 16v | '83 Mk1 L
http://blackgolfgti.blogspot.com
Offline Pete Taylor
Re: Steering problem - HELP!!
« Reply #1 on: 23 April 2008, 20:31 »
Check the fluid. Take the green dipstick cap off and rub the end on a white rag, it should be a red or green colour, if it's brown or black then it needs changing. Also worth seeing if the system needs a quick bleed, start then engine, and with the cap off turn the wheel lock to lock a few times. Could also be the new belt not tight enough. Failing all of that... knackered PAS pump or a leak in a PAS pipe
Offline Greg
« Reply #2 on: 30 April 2008, 21:40 »
Thanks Pete, fluid is greeney brown so will change and see what happens.
Offline Pete Taylor
« Reply #3 on: 30 April 2008, 23:35 »
Let me know if it improves dude
