Author Topic: Hall effect sensor/sender  (Read 1481 times)
2golfshis/hers
« on: 22 April 2008, 21:43 »
Just wondering if anybody knows where I can get on of these from or has a link to get one. The timing on my mk3 8v is spot on so is the dizzy cap so all thats left to do is replace the hall effect sender/sensor and see if that cures the "limp mode"
Offline difficultrogue
Re: Hall effect sensor/sender
« Reply #1 on: 23 April 2008, 05:14 »
Tried to get one! Maindealer only I think!
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 23 April 2008, 23:18 »
Is this part of the dizzy or can it be changed?  I took my dizzy off but cant find a way to change the sensing unit.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline al_bey
« Reply #3 on: 23 April 2008, 23:43 »
I took mine out. You have to take the distributor out and take the c-clip out of the pinion/bottom housing. Then you can pull it through the top. It allows you to then undo the two screws holding in the hall sender unit.
However you are better off going to a scrappy and getting a whole distributor for £15 rather than buying just the sensor from VW for £44, I couldnt believe it!!!!!
